*renumberinternaltosolverid
Renumbers internal IDs to match solver IDs.
*renumberinternaltosolverid entity_type output_mark_id
HyperMesh Tcl Modify Command
entity_type
The type of entity to update. If set to 0, all entities that have solver IDs are considered.
output_mark_id
The ID of the mark containing the renumbered entities. Valid values are 1 and 2.
A value of 0 does not store the renumbered entities.
Examples
To renumber all entities:
*renumberinternaltosolverid 0 0
   # Handle error
Version History
2019
