*linelistbypath
Creates a line path from the starting line to the ending line.
*linelistbypath line_id1 line_id2 list_id flag
HyperMesh Tcl Modify Command
line_id1
The ID of the first line.
line_id2
The ID of the second line.
list_id
The ID of the line list to populate. Valid values are 1 and 2.
flag
0 - If both line_id1 and line_id2 lie are free edges, the path will follow free edges where possible. Otherwise, the shortest path is returned.
1 - Always return the shortest path.
To determine the path between lines 100 and 110 using the shortest path:
*linelistbypath 100 110 1 1
   # Handle error
Version History
11.0.101
