*CE_SetLinkChangeManagerSettings
Modifies/unrealizes/rerealizes connectors when there is change in attribute values or deletion of referenced entities.
*CE_SetLinkChangeManagerSettings perform operation
HyperMesh Tcl Modify Command
perform
0 - Do not perform operation
1 - Perform operation
operation
0 - Modify
1 - Unrealize
2 - Realize
Examples
Modify connectors upon changes:
*CE_SetLinkChangeManagerSettings 1 0
Unrealize connectors upon changes:
*CE_SetLinkChangeManagerSettings 1 1
   # Handle error
Version History
2021
