*normalsdisplay
Turns on the display of 2D and 3D element normals.
*normalsdisplay entity_type mark_id size
HyperMesh Tcl Modify Command
Turns on the display of surface normals.
entity_type
The type of entity to turn on normals for. Valid values are elements and components.
mark_id
The ID of the mark containing the input entities. Valid values are 1 and 2.
size
Specifies the size of the normal graphics to be drawn. If set to zero, the vector is drawn at 10% of the screen size.
To turn on the display of normals for elements 1-10 at 10% screen size:
*createmark elems 1 1-10
*normalsdisplay elems 1 0
   # Handle error
