*createpointsbetweenpoints
Creates a specified number of points between points.
*createpointsbetweenpoints point_id1 point_id2 count
HyperMesh Tcl Modify Command
point_id1
IDs of the points between which the specified number of points will be created.
point_id2
count
The number of points to create.
Examples
This command is called from the Distance panel.
*createpoint(0,0,0,0)
*createpoint(10,0,0,0)
*window(0,0,0,0,0)
*pointmodify(2,5,0,0)
*createpointsbetweenpoints(1,2,1)
