*morphapplylargedomains
Applies current morphing to large domains.
HyperMesh Tcl Modify Command
This command applies any current morphing that affects any large domains to those large domains.
This command is only needed when the bigdomainsolve parameter is set to manual (0.0). For other values the large domain solver will be applied automatically.
None.
