*refineelementsbysize
Refine elements to target element size.
*refineelementsbysize mark maxlength
HyperMesh Tcl Modify Command
mark
The ID of the mark which contains the elements to be refined.
maxlength
The maximum element edge size.
To refine the elements to target element size:
*createmark(elements,1) 12 16 106 107 108 109
*refineelementsbysize(1,0.1)
*createmark()
is required.
None.
