*feinputomitincludefiles
Informs HyperMesh that the next call to *feinputwithdata2 should have the input translator skip over reading include files entirely, and only import the base file.
HyperMesh Tcl Modify Command
After the next call to *feinputwithdata2, HyperMesh will revert to the default behavior of reading and merging include files. For behavior other than the default behavior, this command must be called each time.
