*modent_deleterepresentation
Deletes the representation information from a mark of modular entities.
*modent_deleterepresentation entity_type mark_id content_entity_type representation_key delete_representation_file
HyperMesh Tcl Modify Command
entity_type
The type of modular entity to delete the representation from. Currently only supported for subsystems.
mark_id
The ID of the mark of modular entities. Valid values are 1 and 2.
representation_key
The key of the representation to delete, which is unique per subsystem.
0 - Keep the representation file in the file system
1 - Delete the representation file from the file system
Examples
Delete the information for representation with key "crash5" from subsystem 3, and keep the file in the file system:
*createmark subsystems 1 "by id only" 3
*modent_deleterepresentation subsystems 1 "crash5" 0
   # Handle error
Version History
2020
