*nodecloud2facet
Generate STL facets from a node cloud.
*nodecloud2facet entity_type mark_id reserved "scanradius < radius>;fillholesize <size>"
HyperMesh Tcl Modify Command
entity_type
The type of input entity. Must be set to nodes.
mark_id
The ID of the mark containing the input entities. Valid values are 1 and 2.
reserved
Reserved for future use. Must be set to 5.
"scanradius <radius>;fillholesize <size>"
A string containing extra parameters.
scanradius defines the average distance between input nodes.
fillholesize defines the maximum hole width to close/fill any remaining holes after constructing facets.
Examples
To construct facets from all nodes with scan radius of 4 and post fill hole size of 10:
*createmark nodes 1 all
*nodecloud2facet nodes 1 5 "scanradius 4;fillholesize 10"
   # Handle error
Version History
2020
