*meshspinelements2
Creates solid elements by spinning 2D elements around a plane normal.
*meshspinelements2 mark_id plane_id angle on_spin bias_style biasing organize
HyperMesh Tcl Modify Command
mark_id
The ID of the mark containing the elements to be dragged.
plane_id
The ID of the plane normal about which the elements should be spun, created using *createplane.
angle
The angle which the elements should be spun.
on_spin
The number of elements to create along the spin.
bias_style
The style of biasing to use.
biasing
The biasing intensity value.
organize
0 - Elements to original component
1 - Elements to current component
To create 5 elements by spinning elements 10 and 11 about the plane normal defined by (0.0, 0.0, 1.0) and based at (20.0, 20.0, 0.0) by an angle of 90.0, and have the resulting elems in the original comp:
*createplane 0.0 0.0 1.0 20.0 20.0 0.0
*createmark elements 1 10 11
*meshspinelements2 1 1 90.0 5 1 0.0 0
   # Handle error
Version History
12.0.110
