*setreviewbymarkenhanced
Adds entities to the enhanced review list based on a mark.
*setreviewbymarkenhanced entity_type mark_id color shaded edges
HyperMesh Tcl Modify Command
This command adds entities to the enhanced review list based on a mark. This is similar to *setreviewbymark, but allows for entity shading and edge visualization.
entity_type
The type of entity to add to the review list. Valid values are:
  • nodes
  • elems
  • points
  • lines
  • surfs
  • solids
  • connectors
  • loads
  • equations
  • systs
  • vectors
mark_id
The ID of the mark containing the entities. Valid values are 1 and 2.
color
The color to use for review of the entity. Valid values are 1-64.
shaded
If set to 1, surfaces and elements are put into shaded mode.
edges
If set to 1, surface and element edges are drawn in black.
To review elements 1-100 with color 4 and enabling shading and edge visualization, with all other non-reviewed entities having transparency and gray color:
*createmark elems 1 1-100
*setreviewbymarkenhanced elems 1 4 1 1
*setreviewcolormode 0
*setreviewtransparentmode 1
*setreviewmode 1
   # Handle error
Version History
11.0.130
