*attributeupdatedoublearraymark
Updates an attribute of type double array on a set of entities.
*attributeupdatedoublearraymark entity type mark identifier solver status behavior data length
HyperMesh Tcl Modify Command
entity type
The type of entity that owns the attribute.
mark
The number of the mark.
identifier
The identifier of the attribute.
solver
The solver number of the attribute.
status
The status of the attribute.
behavior
The behavior of the attribute.
data
Double array.
length
Double array length.
Examples
Update an attribute of type double array to [1, 2, 3, and 4] on the materials with IDs 7 and 8.
*createmark(materials,1) 7 8
*createdoublearray(4) 1 2 3 4
*attributeupdatedoublearraymark(materials,1,615,2,2,0,1,4)
