*create_shell_mesh_features
Generates plot elements between 2D elements.
*create_shell_mesh_features entity_type mark_id feature_angle reserved
HyperMesh Tcl Modify Command
Generates plot elements between 2D elements whose normals exceed the a specific angle. Connects features to the boundary or to other features, trying to create convex areas. All features generated are placed into a component named ^feature.
Connected features are created by default for interactive and automatic elements remesh.
entity_type
Entity type containing the 2D elements. Valid values are:
  • comps
  • elems
mark_id
The ID of the mark containing the entities. Valid values are 1 and 2.
feature_angle
The maximum angle allowed between any two plate elements before a plot element is generated between the shared sides of the two elements.
reserved
Reserved for future use. Must be set to 0.
Examples
To create connected lines representing features on the component named "hood" based on a 30.0 degree feature angle:
*createmark components 1 hood
*create_shell_mesh_features component 1 30.0 0
   # Handle error
Version History
11.0
