*linedragelements
Creates a mesh by dragging elements along a line.
*linedragelements mark guide guideendpoints plane_id ondrag biasstyle biasing using_default_vector
HyperMesh Tcl Modify Command
mark
The ID of the mark containing elements.
guide
The guide line.
guideendpoints
The ID of the list containing the nodes which will be used to segment the guide line.
plane_id
The orientation plane used to orient the line to the guide line.
ondrag
The number of elements to be created along the drag.
biasstyle
The type of biasing to use.
biasing
The biasing intensity value.
0 - Use plane normal vector
1 - Use default normal vector
None.
