*defaultmeshsurf_growth
Generates surface meshes using surface deviation parameters with growth ratio transitions given by refinement sizes defined on points, edges and surfaces.
*defaultmeshsurf_growth mark_id elem_size elem_type elem_type_2 previous_settings comp_mode size_control skew_control mesh_type keep_mesh min_size max_size chordal_dev max_angle growth_rate id_array number_of_ids size_array number_of_sizes
HyperMesh Tcl Modify Command
mark_id
The ID of the mark containing the surfaces to mesh. Valid values are 1 and 2.
elem_size
The default element size used to calculate element densities along edges (when necessary).
elem_type
Flag indicating the elements generated for mapped meshing algorithms. Valid values are:
  • 0 - trias
  • 1 - quads
  • 2 - mixed
  • 3 - right trias
  • 4 - quads only
elem_type_2
Flag indicating the elements generated for free meshing algorithms. Valid values are:
  • 0 - trias
  • 1 - quads
  • 2 - mixed
  • 3 - right trias
  • 4 - quads only
previous_settings
Flag indicating whether to break, keep or redo connectivity between neighboring surfaces. Valid values are:
  • 0 - Keep previous settings and do not break connectivity between neighboring surfaces.
  • 1 - Break connectivity between neighboring surfaces.
  • 2 - Keep connectivity between neighboring surfaces.
  • 3 - Redo connectivity between neighboring surfaces by expanding surface selection by one layer of adjacent surfaces.
comp_mode
Parameter specifying how entities are organized into components:
  • 0 - Elements are created in the current component.
  • 1 - Elements are created in the same components as their parent surfaces.
size_control
Flag indicating whether to create uniformly sized elements. Valid values are:
  • 0 - Do not create uniformly sized elements.
  • 1 - Create uniformly sized elements.
skew_control
Flag indicating whether to create optimally shaped elements when using mapping algorithms. Valid values are:
  • 0 - Do not create optimally shaped elements.
  • 1 - Create optimally shaped elements.
mesh_type
Parameter specifying the meshing algorithm for edge/surface meshing. Valid values are:
  • 34 - Proximity and curvature based surface meshing.
  • 35 - Curvature based surfaced meshing.
  • 36 - Proximity and curvature based meshing with free edge deviation.
  • 37 - Curvature based surface meshing with free edge deviation.
keep_mesh
Determines wether any existing mesh is preserved. Valid values are:
  • 0 - Do not keep existing mesh.
  • 1 - Keep existing mesh.
min_size
The minimum edge size.
max_size
The maximum edge size.
chordal_dev
The chordal deviation value.
max_angle
The maximum angle (in degrees) between edges.
growth_rate
The growth rate of the refinement size transition.
id_array
The ID of the string array that contains the refinement geometry IDs. The integer array is created using the *createarray command. This should always be set to 1.
The first three integers indicate the number of source points, edges and surfaces. The next set of integers are the point IDs, followed by the edge IDs, followed by the surface IDs.
number_of_ids
Integer indicating the size (number of integers) in the integer array created using *createarray.
size_array
The ID of the double array that contains the refinement geometry sizes. The double array is created using the *createdoublearray command. This should always be set to 1.
The values must correspond to the same order as the IDs in the id_array.
number_of_sizes
Integer indicating the size (number of doubles) in the double array created using *createdoublearray.
Examples
To create a tria mesh with chordal deviation settings using a growth rate of 1.23 with refinement sources defined at point ID 93, size 1, edge ID 35, size 1.5 and surface ID 2, size 2.1:
*createmark surfaces 1 all
*createarray 6 1 1 1 93 35 2
*createdoublearray 3 1.0 1.5 2.1
*defaultmeshsurf_growth 1 5 0 0 2 1 1 1 35 0 0.5 5 0.1 15 1.23 1 6 1 3
   # Handle error
Version History
11.0
