*makesecondarymodeleditable
Sets the editable state of secondary models.
*makesecondarymodeleditable model_name edit_state
HyperMesh Tcl Modify Command
model_name
The name of the secondary model.
edit_state
0 - Not editable
1 - Editable
Examples
To make the secondary model MyModel editable:
*makesecondarymodeleditable "MyModel" 1
   # Handle error
Version History
2020.1
