*surfacemarksplitwithnodes
Splits a group of surfaces with a smooth line defined by the nodes.
*surfacemarksplitwithnodes mark node_list
HyperMesh Tcl Modify Command
mark
The ID of the mark containing the surfaces
node_list
The list ID of the node to be used.
None.
