*mbplanecreatewithcoords
Creates a new mbplane entity.
*mbplanecreatewithcoords name color type origin origin_size xaxis xaxis_size yaxis yaxis_size multibodyid
HyperMesh Tcl Modify Command
name
The name of the mbplane.
color
The color value of the mbplane.
type
The MADYMO type definition to be used later.
origin
ID of an array containing the coordinates of the the mbplane’s origin node.
origin_size
Size of the origin node array.
xaxis
ID of an array containing the mbplane’s x-axis node.
xaxis_size
Size of the xaxis node array.
yaxis
ID of an array containing the mbplane’s y-axis node.
yaxis_size
Size of the yaxis node array.
multibodyid
The ID of the multibody to which the mbplane is attached.
To create an MB plane with the name "kneebolsterplane":
*createdoublearray(3) 7 0 20
*createdoublearray(3) 0 0 20
*createdoublearray(3) 0 20 0
*mbplanecreatewithcoords("kneebolsterplane",29,0,1,3,1,3,1,3,1)
None.
