*loadtype
Sets the load types to the current global value.
*loadtype config type
HyperMesh Tcl Modify Command
config
The load configuration that is to have its type changed.
type
The type which the configuration should become.
To set the type of forces to 2:
*loadtype(1,2)
After the type has been set, all loads of the corresponding configuration are set to the value of type.
None.
