*CE_ConnectorRemoveDuplicates
Deletes connectors that are considered to be duplicates of other connectors within a given tolerance.
*CE_ConnectorRemoveDuplicates markMask tolerance
HyperMesh Tcl Modify Command
markMask
The mark mask (1 or 2).
tolerance
The maximum distance between two connectors that are considered to be duplicates.
Examples
To delete duplicate connectors on the mark mask 1 within 0.05 tolerance:
*CE_ConnectorRemoveDuplicates(1, 0.05)
Currently only supported for connectors located at geometric points.
