*stiffenedpanelmesh
Creates a stiffened panel mesh between lines or on surfaces.
*stiffenedpanelmesh entity_type1 entity_type2 ?option1=<value1>? ?<option2>=<value2>? ... ?<optionN>=<valueN>?
HyperMesh Tcl Modify Command
<option>=<value> options can be provided in any order.
entity_type1
Must be set to lines.
entity_type2
Must be set to surfaces.
BoundCurveU=<value>
The ID of the curve to specify the U direction. Renumbering will begin where it intersects the BoundCurveV.
BoundCurveV=<value>
The ID of the curve to specify the V direction. Renumbering will begin where it intersects the BoundCurveU.
CompName=<value>
The prefix name of the components to create for beams and shells.
DeleteGeom=<value>
The option to keep or delete new geometries. This is a mandatory option.
0 - Keep new geometries
1 - Delete new geometries
DestinationComp=<value>
The component organization. This is a mandatory option.
0 - New component
1 - Current component
ElementID=<value>
The start ID for element numbering.
ElementU=<value>
The number of shell elements in each panel in the U direction.
ElementU=<value>
LineMark=<value>
The ID of the mark containing the input lines. Valid values are 1 and 2.
NodeID=<value>
The start ID for node numbering.
NoIntersectLineMark=<value>
The ID of the mark containing the lines which are non-parallel and non-intersecting to LineMark. Valid values are 1 and 2.
ManifoldSurf=<value>
The option to create mesh in the surfaces:
0 - Do not mesh surfaces
1 - Mesh surfaces
SurfaceMark=<value>
The ID of the mark containing the input surfaces. Valid values are 1 and 2.
Tolerance=<value>
The tolerance for considering line intersections.
To create stiffened panel mesh between selected lines:
*createmark lines 1 37 39 41 43 52
*createmark lines 2 21-25
*stiffenedpanelmesh lines surfs LineMark=1 NoIntersectLineMark=2 SurfaceMark=2 BoundCurveU=49 BoundCurveV=25 Tolerance=2.9149397464082 CompName=mypanel DestinationComp=0 DeleteGeom=1 ElementID=2004 NodeID=1138 ManifoldSurf=0 ElementU=2 ElementV=3
   # Handle error
Version History
2019.1
