*titlemodify
Modifies a title entity.
*titlemodify titlename itemname string value plot
HyperMesh Tcl Modify Command
titlename
The name of the title.
itemname
The name of the item to be modified. itemname can be one of the following options:
titlecolor - Title color, 0 through 64.
titlefont - Font used to display text (1-4, with 1 being the smallest font and 4 being the largest).
titleanchor - Anchor corner of the title.
  • 0 - lower left
  • 1 - upper left
  • 2 - upper right
  • 3 - lower right
border on - Turns the border on and off.
  • 1 - turn border on
  • 0 - turn border off
borderwidth - Width of the border.
borderxmin - Minimum x value of the border.
borderxmax - Maximum x value of the border.
borderymin - Minimum y value of the border.
borderymax - Maximum y value of the border.
titletext - Set the title text to string.
string
The string value to which the modified item should be set. When itemname is titletext, the title displays a string.
value
The value to which the modified item should be set. Used for all itemnames, except titletext.
plot
Designates whether the title will be plotted after modification.
1 - Plot the title after modification.
0 - Do not plot the title after modification.
*titlemodify("test","borderon","",1,0)
*titlemodify("test","bordercolor","",4,0)
*titlemodify("test","titletext","This is test",0,1)
*titlemodify("test","titlefont","",3,1)
*titlemodify("test","titleanchor","",1,1)
*titlemodify("test","borderxmin","",0.469273743,0)
*titlemodify("test","borderymin","",0.120287253,0)
None.
