*hf_CreatePol
Creates POL from the current trim line, with the specified offset.
*hf_CreatePol offset
HyperMesh Tcl Modify Command
This command creates POL from the current trim line, with the specified offset.
offset
The offset specified for the POL.
To create POL from the current trim line with offset of 100:
*hf_CreatePol 100
   # Handle error
Version History
11.0
