*elementqualityswapedgenew
Switches the connectivity of the two elements that share the specified edge to the next legal configuration.
*elementqualityswapedgenew element_id edge_index
HyperMesh Tcl Modify Command
This command switches the connectivity of the two elements that share the specified edge to the next legal configuration.
This command only functions between an *elementqualitysetup command and an *elementqualityshutdown command.
element_id
The element ID.
edge_index
The index of the edge to swap, starting from 0.
To swap elements 27 edge 3, 22 edge 0, 21 edge 2 and 26 edge 1:
*createmark elems 1 displayed
*elementqualitysetup 1
*elementqualityswapedgenew 27 3
*elementqualityswapedgenew 22 0
*elementqualityswapedgenew 21 2
*elementqualityswapedgenew 26 1
*elementqualityshutdown 1
   # Handle error
Version History
12.0.110
