*elementtestequiaskew
Tests 2D and 3D elements using the equiangle skew element quality check.
*elementtestequiaskew entity_type mark_id equiangle_skew output_mark_id dimension contour title
HyperMesh Tcl Modify Command
entity_type
The entity types to be checked. Only elements are supported.
mark_id
The mark ID containing the elements to test. Valid values are 1 and 2.
equiangle_skew
The value to use as a threshold beyond which elements should be considered to have failed the test.
dimension
A code telling to measure the dimension of:
  • 2 - Measure 2D elements.
  • 4 - Measure 3D elements.
output_mark_id
The mark ID where the failed elements will be placed. Valid values are 1 and 2.
contour
Flag that determines how the results are presented. Valid values are:
  • 0 - Display the results of the test normally.
  • 1 - Display the elements color coded by their ratings.
  • 2 - Build a histogram showing the distribution of ratings.
title
The title to label the curve in the histogram. Only required, if contour is 2.
To test all displayed elements for a cell squish of 0.7:
*createmark elems 1 "displayed"
*createmark elems 2
*elementtestequiaskew elems 1 0.7 0 0 ""
   # Handle error
Version History
11.0
