*hf_EditPol
Opens the Section Editor and loads the POL profile into the 2D editor.
*hf_EditPol reserved
HyperMesh Tcl Modify Command
This command opens the Section Editor and loads the POL profile into the 2D editor.
reserved
Reserved for future use. Must be set to 0.
To edit the POL profile:
*hf_EditPol 0
   # Handle error
Version History
11.0
