*convertinclude
Converts a regular include file into an include transform include file or vice versa.
*convertinclude id shortname flag
HyperMesh Tcl Modify Command
id
The include ID, or 0 to use shortname.
shortname
The short name of the include file. This can be empty if id is specified other than 0.
flag
1 - Convert a regular include into an include transform include
2 - Convert an include transform include into a regular include
To convert regular include file with ID 10 into an include transform include file:
*convertinclude 10 "" 1
   # Handle error
Version History
2019.1
