*meshline_mark_entity_inside_class
Marks entities as being inside a meshline class.
*meshline_mark_entity_inside_class entity_type mark_id1 mark_id2
HyperMesh Tcl Modify Command
This command marks entities as being inside a meshline class.
entity_type
The type of entity to mark. Valid values are nodes and elements.
mark_id1
The ID of the mark containing the new entities to add. Valid values are 1 and 2.
mark_id2
The ID of the mark containing the previous entities. Valid values are 1 and 2.
To add element 500 inside a meshline class:
*createmark elems 1 500
*meshline_mark_entity_inside_class elems 1 2
   # Handle error
Version History
11.0
