*morphconstraintupdateavm
Updates a model type constraint based on the area, volume, or mass of the elements on the mark.
*morphconstraintupdateavm stype smark etype emark type mcon target bound color
HyperMesh Tcl Modify Command
This command updates a model type constraint for the elements on the mark with the option of having the area, volume, or mass forced to be greater than, less than, or equal to the specified value.
The shapes on the mark will be used to force the model into compliance with the specified constraint if possible.
stype
Must be set to shapes.
smark
The ID of the mark containing the shapes. Valid values are 1 and 2.
etype
Must be set to elements.
emark
The ID of the mark containing the elements. Valid values are 1 and 2.
type
0 - Area
1 - Volume
2 - Mass
mcon
The ID of morph constraint to update.
target
The constrained value for area, volume, or mass.
bound
-1 - Greater than specified target
0 - Equal to specified target
1 - Less than specified target
color
The color of the constraint. Valid values are 1 through 64.
To update a constraint named "area" where the area is specified to be exactly 3600:
*morphconstraintupdateavm shapes 1 elements 1 0 5 3600.0 0 32
   # Handle error
