Deprecated Tcl Modify Commands
The list of deprecated Tcl modify commands, and the new commands to use.
Deprecated Commands New Commands to Use
*accepteditedsurface *accepteditedsurface_with_user_tolerance
*add_washer_elements *add_multi_washer_elements
*admasconnectivityupdatemultentselect *admasconnectivityupdatemultentselectwithvisnod
*admascreatemultentselect *admascreatemultentselectwithsets
*allowduplicateids *setoption duplicate_ids
*bagcreate *createentity
*bagentityupdate *setvalue
*beadboundsupdate *setvalue
*beadparamsupdate *setvalue
*beamsectioncreatestandard *beamsectioncreatestandardsolver
*bitmapanimationmode *setoption bitmap_animation_mode
*blockcreate *createentity
*blockupdate *setvalue
*cardcreate *createentity
*CE_FE_AbsorbAndCreate
*centroid1dmode *setoption 1d_at_centroid
*change_distance_between_faces *setvalue
*cleanuptoleranceset *setoption cleanup_tolerance
*clipboundaryelements *setoption clip_boundary_elements
*coarsen_and_decimate_mesh *coarsen_and_decimate_mesh2
*coincidentnodepickmode *setoption coincident_picking
*coincidentpickmode *setoption coincident_picking
*collectorcreate *createentity
*collectorcreateonly *createentity
*collectorcreatesameas *createentitysameas
*component_changesurflines *setoption surface_uv_lines
*compositeshuffledesvarcreate *createentity
*compositeshuffledesvarcreatewithlaminateoption *createentity
*compositeshuffledesvarupdate *setvalue
*compositeshuffledesvarupdatewithlaminateoption *setvalue
*compositeshufflepairingconstraintupdate *setvalue
*compositesizedesvarcreate *createentity
*compositesizedesvarcreatewithlaminateoption *createentity
*compositesizedesvarupdate *setvalue
*compositesizedesvarupdatewithlaminateoption *setvalue
*compositesizelaminatethicknessupdate *setvalue
*connect_surfaces *connect_surfaces_11
*connect_surfaces_over_edges *connect_surfaces_11
*control_sum *control_sum_print
*control_sum_2 *control_sum_print
*control_sum_3 *control_sum_print
*createellipsoid *createellipsoids
*createellipsoidbypoint *createellipsoidsbypoints
*create2dseatbelt *createentity
*create2dseatbeltwithmeshelementsize *createentity
*create_sbelt *createentity
*create_sbelt2D *createentity
*createblockwithsystem *createentity
*createnode *createentity
*createseatbelt *createentity
*createseatbeltline *createentity
*createseatbeltlinewithmesh *createentity
*createseatbeltmesh *createentity
*createseatbeltsurfaceandlines *createentity
*createseatbeltsurfaceandlinesUsingOrientNode *createentity
*createsimpleblock *createentity
*ddvaladdrange *setvalue
*ddvaladdvalues *setvalue
*ddvalcreate *createentity
*deleteelementsmode *setoption delete_elements_mode
*dequationcreate *createentity
*dequationupdate *setvalue
*desvarlinkcreate *createentity
*desvarlinkcreatewithfunction *createentity
*desvarlinkupdate *setvalue
*desvarlinkupdatewithfunction *setvalue
*detailedelements *setoption detailed_elements
*detailedelements_beamvis *setoption detailed_elements_beamvis
*detailedelements_shellvis *setoption detailed_elements_shellvis
*dictionaryload *createentity/*setvalue
*dictionaryreset *setvalue
*dictionaryresetsolver *setvalue
*dictionaryupdatebymark *setvalue
*dictionaryupdateentry *setvalue
*displayimporterrors *setoption display_import_errors
*dvprelcreate *createentity
*dvprelupdate *setvalue
*elementhandle *setoption element_handle
*elementorder *setoption element_order
*elementqualityoptimizeelement *elementqualityoptimizeelementnew
*elementqualityoptimizenode *elementqualityoptimizenodenew
*elementqualityoptimizenode1 *elementqualityoptimizenodenew
*elementqualityplacenode *elementqualityplacenodenew
*elementqualityplacenode1 *elementqualityplacenodenew
*elementqualitysmoothnodes *elementqualitysmoothnodesnew
*elementqualityswapedge *elementqualityswapedgenew
*elementsizeset *setoption element_size
*ellipsoidupdate *setvalue
*entityhighlighting *setoption entity_highlighting
*entitysetaddentities *setvalue
*entitysetcreate *createentity
*entitysetcreatelist *createentity
*entitysetdelentities *setvalue
*entitysetupdate *setvalue
*entitysetupdatelist *setvalue
*entitysuppressactive *setvalue
*entitysuppressoutput *setvalue
*equationhandle *setoption equation_handle
*equationupdate *setvalue
*equationupdateallconstant *setvalue
*equationupdatealldofswts *setvalue
*exponentialdisplay *setoption exponential_display
*featureangleset *setoption feature_angle
*feinput *feinputwithdata2
*feinput2 *feinputwithdata2
*feinputdefault *feinputwithdata2
*feinputwithdata *feinputwithdata2
*feoutput *feoutputwithdata
*feoutputtimeinfo *setoption feoutput_time_info
*fieldofview *setoption perspective_fov
*findflangesend/*findflangesinit/*findflangesproximityshell/*findflangestoposhell hm_flangedetectioninit family of commands
*findholesend/*findholesinit/*findholesshell/*findholessolid hm_holedetectioninit family of commands
*findnodesbetweencomponents *findbetween
*fixedpointhandle *setoption fixed_point_handle
*forcetextblack *setoption force_text_black
*formulasetcreate *createentity
*formulasetcreateall *createentity
*formulasetcreatelist *createentity
*formulasetcreaterange *createentity
*formulasetcreaterangewithexcept *createentity
*formulasetdeleteclause *setvalue
*freeshapedesvarcreate *createentity
*freeshapedesvarcreatewithsetoption *createentity
*freeshapedesvarupdate *setvalue
*freeshapedesvarupdatewithsetoption *setvalue
*freeshapedrawextrusionpdate *setvalue
*freeshapegridconstraintsupdate *setvalue
*freeshapegridconstraintsupdatewithsetoption *setvalue
*freeshapeparametersupdate *setvalue
*freeshapeparametersupdatewithlimits *setvalue
*freeshapeparametersupdatewithsmoothing *setvalue
*freeshapeparametersupdatewithtransition *setvalue
*freeshapepatternupdate *setvalue
*freeshapesideconstraintsbarrierupdatebyblocks *setvalue
*freeshapesideconstraintsbarrierupdatemanual *setvalue
*freesizedesvarcreate *createentity
*freesizedesvarcreatewithlaminateoption *createentity
*freesizedesvarcreatewithstackoption *createentity
*freesizedesvarupdate *setvalue
*freesizedesvarupdatewithlaminateoption *setvalue
*freesizedesvarupdatewithstackoption *setvalue
*freesizelaminatethicknessupdate *setvalue
*freesizeparametersupdate *setvalue
*freesizeparametersupdatewithfatigue *setvalue
*freesizepatternupdate *setvalue
*freesizerepetitionupdate *setvalue
*freesizesymmetryupdate *setvalue
*freesizeupdatetapeattribute *setvalue
*freesizezonebasedupdate *setvalue
*gaugedesvarcreate *createentity
*gaugedesvarcreategeneralized *createentity
*gaugedesvarcreatewithddvalfield *createentity
*gaugedesvarupdate *setvalue
*gaugedesvarupdategeneralized *setvalue
*gaugedesvarupdatewithddvalfield *setvalue
*geometrytoleranceset *setoption cleanup_tolerance
*geomfeatureangleset *setoption geom_feature_angle
*geomoutputdata *geomexport
*geomoutputdata2 *geomexport
*geomstitching *setoption geom_stitching
*graphic_label *setoption load_solver_label
*graphicsfileblankbackground *setoption graphics_file_blank_background
*graphicsimplificationmode *setoption graphics_simplification_component
*setoption graphics_simplification_mode
*hf_CheckDieModuleElements
*hf_CreateAutomaticTL
*hf_trim *hf_trim_multi
*hm_autocleanup *autotopocleanup
*hm_auto_elem_cleanup *hm_auto_elem_cleanup_new
*hyperbeambatch
*iges_write *geomexport
*iges_write_units *geomexport
*importacis *geomimport
*importdes *geomimport
*importdxf *geomimport
*importinca *geomimport
*importparasolid *geomimport
*importpdgs *geomimport
*interfaceall *setvalue
*interfacebox *setvalue
*interfacecomponent *setvalue
*interfacecreate *createentity
*interfacecreatewithid *createentity
*interfacecontactsurf *setvalue
*interfacedefinition *setvalue
*interfacesets *setvalue
*jointelement_update *setvalue
*laminatecreate *createentity
*laminateupdate *setvalue
*latparmcreate *createentity
*latparmupdate *setvalue
*latparmupdatebucksfparameter *setvalue
*latparmupdatemaxradparameter *setvalue
*linefromsurfedge *linefromsurfedgecomp
*linehandle *setoption line_handle
*linemarkcombine *linecombine
*linemesh_preparedata *linemesh_preparedata1
*linemesh_preparenodeslist *linemesh_preparenodeslist1
*linemesh_savedata *linemesh_savedata1
*linemesh_savedata_bar *linemesh_savedata_bar1
*loadhandle *setoption load_handle
*loadlabel *setoption load_label
*loadlabelsetcolor *setoption load_label_color
*loadsize *setoption load_size_magnitude
*setoption load_size_type
*setoption load_size_uniform
*loadstepscreate *createentity
*loadstepscreatesameas *createentitysameas
*loadstepsupdate *setvalue
*loadstepsupdateattributesfromidlist *setvalue
*loadvisualvector *setoption load_visual_vector
*marksuppressactive *setvalue
*marksuppressoutput *setvalue
*maskmark *maskentitymark
*masselementupdate *setvalue
*materialupdate *setvalue
*mbjointupdate *setvalue
*meshdragelements *meshdragelements2
*meshspinelements *meshspinelements2
*midsurface_accept_edge_target *midsurface_accept_edge_target_by_number
*midsurface_extract_new *midsurface_extract_10
*midsurface_offset_by_targets *midsurface_offset_by_targets_11
*midsurface_remove_edge_target *midsurface_remove_edge_target_by_number
*mixedpropertywarning *setoption mixed_property_warning
*morphaddconstraint *morphconstraintcreatefc
*morphaddconstraintline *morphconstraintcreateline
*morphaddconstraintplane *morphconstraintcreateplane
*morphaddconstraintsurface *morphconstraintcreatesurf
*morphaddconstraintvector *morphconstraintcreatevec
*morphalterangle *morphalteranglevec
*morphaltercurvature *morphaltercurvectr
*morphalterdistance *morphalterdistancevec
*morphalterradius *morphaltercurvectr
*morphcreate *morphcreatedomaindc
*morphcreatedomain *morphcreatedomaindc
*morphcreatedomainglobal *morphcreatedomainglobalnodes
*morphmanualapply *morphmanualapplyenvelope
*morphmapedgestoequation *morphmapedgestoequationoffset
*morphmapedgestoline *morphmapedgestolineoffset
*morphmapedgestonodes *morphmapedgestonodelistoffset
*morphmapedgestonodesoffset *morphmapedgestonodelistoffset
*morphmapedgestoplane *morphmapedgestoplaneoffset
*morphmapedgestosurface *morphmapedgestosurfaceoffset
*morphmapedgestotacit *morphmapedgestotacitoffset
*morphmaptoequation *morphmaptoequationvecoffset
*morphmaptoequationvec *morphmaptoequationvecoffset
*morphmaptoline *morphmaptolinevecoffset
*morphmaptolinenodes *morphmaptolinenodesoffset
*morphmaptolineoffset *morphmaptolinenodesoffset
*morphmaptolinevec *morphmaptolinevecoffset
*morphmaptonodesnodes _morphmaptonodesnodeslistoffset.htm#_morphmaptonodesnodeslistoffset
*morphmaptonodesnodesoffset _morphmaptonodesnodeslistoffset.htm#_morphmaptonodesnodeslistoffset
*morphmaptonodesvec *morphmaptonodelistvecoffset
*morphmaptonodesvecoffset *morphmaptonodelistvecoffset
*morphmaptoplane *morphmaptoplanevecoffset
*morphmaptoplanevec *morphmaptoplanevecoffset
*morphmaptosurface *morphmaptosurfacevecoffset
*morphmaptosurfacevec *morphmaptosurfacevecoffset
*morphmaptotacitvec *morphmaptotacitvecoffset
*morphnodesequa *morphnodesequaoffset
*morphnodesequaenvelope *morphnodesequaoffset
*morphnodesline *morphnodeslineoffset
*morphnodeslineenvelope *morphnodeslineoffset
*morphnodesmesh *morphnodesmeshoffset
*morphnodesmeshenvelope *morphnodesmeshoffset
*morphnodesnodes *morphnodesnodesoffset
*morphnodesnodesenvelope *morphnodesnodesoffset
*morphnodesnormal *morphnodesnormalenvelope
*morphnodesplane *morphnodesplaneoffset
*morphnodesplaneenvelope *morphnodesplaneoffset
*morphnodesrotate *morphnodesrotateenvelope
*morphnodesshape *morphnodesshapeenvelope
*morphnodessurf *morphnodessurfoffset
*morphnodessurfenvelope *morphnodessurfoffset
*morphnodestranslate *morphnodestranslateenvelope
*morphnodesvector *morphnodesvectoroffset
*morphnodesvectorenvelope *morphnodesvectoroffset
*morphorganizedomainedge *morphcombineedges
*morphpositionshape *morphpositionshapemark
*morphreflectshape *morphreflectshapemark
*morphremesh *morphremeshedges
*morphsculptmesh *morphsculptmesh3
*morphsculptmesh2 *morphsculptmesh3
*morphsculptmeshfea *morphsculptmesh3
*morphshapecreate *morphshapecreatecolor
*morphsymmetrycreate *morphsymmetrycreateaxis
*morphsymmetryupdatebys *morphsymmetryupdateaxis
*morphtranslateshape *morphtranslateshapemark
*morphupdategraphics *morphupdateparameter
*morphupdateparameter domainicons *setoption domain_handle
*multibody_cogupdate *setvalue
*multibody_sysupdate *setvalue
*multibodycreate *createentity
*multibodycreate_body *createentity
*multibodycreate_duplicate *createentitysameas
*multibodycreate_use *createentity
*nodesassociatetosolid *nodesassociatetogeometry
*nodesassociatetosurface *nodesassociatetogeometry
*normalsadjust *normalsadjust2
*opticonstraintcreate *createentity
*opticonstraintupdate *setvalue
*opticontrolcreate *createentity
*opticontrolcreate80 *createentity
*opticontrolcreate80sr1 *createentity
*opticontrolupdate *setvalue
*opticontrolupdate80 *setvalue
*opticontrolupdate80sr1 *setvalue
*opticontrolupdateapproxparameters *setvalue
*opticontrolupdatebarconparameters *setvalue
*opticontrolupdatecontolparameters *setvalue
*opticontrolupdateeslparameters *setvalue
*opticontrolupdatemanthrparameters *setvalue
*opticontrolupdateoptimizationparameters *setvalue
*opticontrolupdateremeshparameters *setvalue
*opticontrolupdatetopdiscparameters *setvalue
*opticontrolupdatetopdvparameters *setvalue
*opticontrolupdatetoprstparameters *setvalue
*optictrlcreate *createentity
*optictrlupdate *setvalue
*optidobjrefcreate *createentity
*optidobjrefupdate *setvalue
*optidscreencreate *createentity
*optidscreencreateextended *createentity
*optidscreenupdate *setvalue
*optidscreenupdateextended *setvalue
*optiminmaxcreate *createentity
*optiminmaxupdate *setvalue
*optimized_elements_remesh *optimized_elements_remesh2
*optiobjectivecreate *createentity
*optiobjectiveupdate *setvalue
*optiresponsecreate *createentity
*optiresponseexcludeelements *setvalue
*optiresponsesetequationdata1 *setvalue
*optiresponsesetequationdata2 *setvalue
*optiresponsesetequationdata3 *setvalue
*optiresponsesetequationdata4 *setvalue
*optiresponseupdate *setvalue
*optiresponseupdatenodeid *setvalue
*optiresponseupdatenormalacceleration *setvalue
*optiresponseupdatenormaldisplacement *setvalue
*optiresponseupdatenormalvelocity *setvalue
*optiresponseupdaterandpsid *setvalue
*optiresponseupdatesubcasetrackingvalue *setvalue
*optitableentrycreate *tablecreate and *tableaddrow
*optitableentryupdate *tableupdaterow
*ossmooth *ossmooth2
*ossmooth_post *ossmooth2
*outputblockscreate *createentity
*outputblocksupdate *setvalue
*perspectiveview *setoption perspective_view
*picktoleranceset *setoption pick_tolerance
*plycreate *createentity
*plythicknessfactor *setoption ply_thickness_factor
*plyrealization *plyrealization_option
*plyupdate *setvalue
*propertyupdate *setvalue
*propertyupdateentity *setvalue
*rbe3update *setvalue
*rbe3updatealldofs *setvalue
*rbe3updateallwts *setvalue
*rbe3updatedofs *setvalue
*rbe3updatewts *setvalue
*ReassignSeatbeltRodNodes *setvalue
*rejectbatchmesh *rejectmark
*reset_qa_calculator *setqualitycriteria
*reset_qa_calculator_from_file *readqualitycriteria
*restoreview *restoreviewmask
*resultcolortypemode *setoption contour_type
*retainloads *setoption retain_loads
*rigidlinkupdate *setvalue
*rigidsupdate *setvalue
*rigidsupdate_setattach *setvalue
*rigidsupdateconnectivity *setvalue
*rigidwall_motion_update *setvalue
*rodupdate *setvalue
*rotationangleset *setoption rotation_angle_set
*rotationcentermode *setoption rotation_center_mode
*rotationcenteroffscreen *setoption rotation_center_off_screen
*saveview *saveviewmask
*seatbeltnodecreate *createentity
*secondorderfix *secondorderfix2
*separate_holes_in_3d_body *separate_holes_in_3d_body_new
*setautomeshcolormode *setoption auto_mesh_color_mode
*setbackgroundcolor *setoption background_colors
*setbackgroundcolors *setoption background_colors
*setchordaledgeparams *set_meshedgeparams
*setdisplaycolor *setoption display_color
*setedgemeshparams *set_meshedgeparams
*setelementcolormode *setoption element_color_mode
*setelementinternaledgesmode *setoption element_internal_edges_mode
*setfacemeshparams *set_meshfaceparams
*setgeomrefinelevel *setoption geom_refine_level
*setgeomtopologydisplay *setoption topology_display_mode
*setgraphicsengine
*setlodthreshold *setoption lod_threshold
*sethvlaunchflag *setoption hv_launch_flag
*setmeshlodthreshold *setoption mesh_lod_threshold
*setmeshlinecolor *setoption mesh_line_color
*setmeshtransparency *setoption mesh_transparency
*setperformancenormalmode *setoption performance_normal
*setscaleoption *setoption scale_color
*setoption scale_height
*setoption scale_position
*setoption scale_width
*setspecularity *setoption lighting_mode=0, and specular_intensity
*settopologydisplay *setoption topology_display_mode
*settopologydisplayall *setoption topology_display_mode
*settopologydisplaymode *setoption topology_display_mode
*settopologyedgedisplay *setoption topology_edge_display_mode
*settopologysoliddisplay *setoption solid_transparency
*setoption topology_solid_display_mode
*settransparentwithmeshlines *setoption transparent_with_mesh_lines
*shapeboundsupdate *setvalue
*shapeboundsupdatewithddvalfield *setvalue
*shapedesvarcreate *createentity
*shapedesvarsupdate *setvalue
*shapevarcreate *createentity
*shapevarcreate_twonode *createentity
*shapevarupdate *setvalue
*shapevarupdate_twonode *setvalue
*show_new_edge_target *show_new_edge_target_by_number
*showcompositelayers *setoption show_composite_layers
*showgeomlinedir *setoption show_line_dir
*showglobalaxes *setoption show_global_axes
*showscale *setoption show_scale
*shpdesvarcreate *createentity
*shpdesvarcreatewithddvalfield *setvalue
*shpdesvarupdate *createentity
*shpdesvarupdatewithddvalfield *setvalue
*shrink *setoption shrink_factor
*setoption shrink_mode
*simulationset *inputsimulation
*sizedesvarcreate *createentity
*sizedesvarcreatewithddvalfield *createentity
*sizedesvarupdate *setvalue
*sizedesvarupdatewithddvalfield *setvalue
*solid_spin_from_surfs *solidcreatespinsurfwithoffsetangle
*sphgenerate *sphgenerate_new
*spinlinetoformsurface *surfacecreatespinlinewithoffsetangle
*spinnodestoformsurface *surfacecreatespinnodeswithoffsetangle
*stereodisplay *setoption stereo_display
*storeAMelemstodatabase *storemeshtodatabase
*surface_chordalmesh *defaultremeshsurf
*surfacefiller *surfacesplinefillholes and *surfacesplineonlinesloop
*surfacemarkchangesurfacelines *setoption surface_uv_lines
*surfacemarkcombine *selfstitchcombine
*surfacereversenormals *surfacereversenormals2
*surfacesextendintersect *connect_surfaces_11
*surfacesplineonnodesloop *surfacesplineonnodesloop2
*surfaceuvlines *setoption surface_uv_lines
*surfisolinecreate *linecreateatsurfparams
*surfmarkoffsetplusminus *offset_surfaces_and_modify
*systemcreate *system
*systemdeleteunused *EntityPreviewUnused and *deletemark
*systempreviewunused *EntityPreviewUnused
*systemsetanalysis *setvalue
*systemsetreference *setvalue
*systemsize *setoption system_size
*tagcreate *createentity
*tagcreatelabelbyid *createentity
*tagdisplay *setoption tag_display
*tagtextdisplaymode *setoption tag_text_display_mode
*tagupdate *setvalue
*tagupdatedescription *setvalue
*tagupdateentity *setvalue
*tetra_cfdmesh *tetmesh
*tetra_cfdmesh_transition *tetmesh
*tetra_remesh *tetmesh
*tetra_remesh_transition *tetmesh
*tetra_volumemesh *tetmesh
*tetra_volumemesh_transition *tetmesh
*tetramesh *tetmesh
*tetramesh_transition *tetmesh
*thick1dlines *setoption thick_1d_lines
*thickmeshlines *setoption thick_mesh_lines
*toleranceset *setoption node_tolerance
*topographyboundsupdate *setvalue
*topographydesvarcreate *createentity
*topographydesvarupdate *setvalue
*topographypatternupdate *setvalue
*topographypatternvaluesupdate *setvalue
*topographyrepetitionupdate *setvalue
*topologydesvarcreate *createentity
*topologydesvarupdate *setvalue
*topologydrawupdate *setvalue
*topologydrawupdatewithnoholeandstamp *setvalue
*topologyextrusionupdate *setvalue
*topologylatticeupdate *setvalue
*topologyparametersupdate *setvalue
*topologyparametersupdate80 *setvalue
*topologyparametersupdatewithfatigue *setvalue
*topologyparametersupdatewithmingap *setvalue
*topologyparamsupdate *setvalue
*topologypatternupdate *setvalue
*topologyrepetitionupdate *setvalue
*topologysymmetryupdate *setvalue
*trim_elements *trim_elements2
*trim_elems_by_circular_hole *trim_elems_by_multi_circular_hole
*unmaskmark *unmaskentitymark
*unmaskmarkedelements *unmaskentitymark
*updateblock *setvalue
*updateblocks *setvalue
*updateblockwithsystem *setvalue
*updatecolor
*updateincludedata *updateincludedata2
*updateseatbelt *setvalue
*updatesimpleblock *setvalue
*vectorautoscale *setoption vector_auto_scale
*vectorcreate *createentity
*vectorcreate_twonode *createentity
*vectordrawoptions *setoption vector_size_magnitude
*setoption vector_size_type
*setoption vector_size_uniform
*vectorhandle *setoption vector_handle
*vectorlabel *setoption vector_label
*vectorupdate *setvalue
*vectorupdate_twonode *setvalue
*writeh3d *writeh3dwithoptions
*writeh3dtofile *writeh3dwithoptions
*writeh3dwithorienttofile *writeh3dwithoptions
*writeh3dwithtitlestofile *writeh3dwithoptions
*writequalitycriteria *writecurrentqualitycriteria
*zoomfactorset *setoption zoom_factor
