*cuttingplanereverse
Reverses a cutting plane display orientation.
*cuttingplanereverseaxis
HyperMesh Tcl Modify Command
axis
The axis that is normal to the plane. Valid values are:
  • 0 - The plane with x-axis as its normal.
  • 1 - The plane with y-axis as its normal.
  • 2 - The plane with z-axis as its normal.
Examples
To reverse the cutting plane with y-axis as its normal:
*cuttingplanereverse 1
   # Handle error
