*mechjointlimits
Sets the type of limits to use on joints for the current dummy.
*mechjointlimits limits
HyperWorks Tcl Query Command
The mechanism must have the enabled flag set to true for this to be possible.
limits
0 - Hard limits (default)
1 - Soft limits
To activate soft limits on the current dummy:
*mechjointlimits 1
   # Handle error
Version History
14.0.120
