*rigidlinkupdatebycollector
Updates connectivity and properties of a rigid link element with one independent node and dependent node defined by collector.
*rigidlinkupdatebycollector element_id node_id mark_id entity_type
HyperMesh Tcl Modify Command
This command updates the rigid link with one independent node and dependent node by collector by mark.
element_id
The id of the rigid link.
node_id
ID of independent node.
mark_id
Collector put on mark. Valid values are 1 and 2.
entity_typ
Entity type of collector. Valid entity types are comps, mats, assems, props and sets.
To update a rigid link element ID 7 with independent node ID 10 and dependent node specified by comps ID 1 and 2 put on mark 1:
*createmark comps 1 1 2
*rigidlinkupdatebycollector 7 10 1 comps
None.
Version History
9.0
