*createvector
Defines a vector for use in a subsequent command.
*createvector vector_id x_component y_component z_component
HyperMesh Tcl Modify Command
The vector length should never be 0.
Use the *createetity command to create a vector entity.
vector_id
The ID of the vector being defined. Valid values are 1 and 2.
x_component
The x-component of the normal of the vector.
y_component
The y-component of the normal of the vector.
z_component
The z-component of the normal of the vector.
Examples
To define a vector along the y-axis:
*createvector 1 0.0 1.0 0.0
