*calculateproximityelements
Used to determine the proximity distance between elements.
*calculateproximityelements entity_type input_mark_id output_mark_id dim_type calc_type self_interference check_method proximity_dist pair_angle threshold_depth
HyperMesh Tcl Modify Command
This command allows you to find which input elements are within a specified proximity distance. There are options to narrow or expand the constraints placed on the search algorithm. These constraints include, dimension of elements considered, type of interference, whether elements of the same component can interfere, angle between interfering element face normals and a threshold depth.
entity_type
The type of entity to check for element proximity: elems or comps.
input_mark_id
Input mark ID containing either components or elements.
output_mark_id
Output mark ID containing elements within proximity distance.
dim_type
The dimensionality of the elements to check:
0 - Check both 2D and 3D elements.
2 - Only check 2D elements.
3 - Only check 3D elements.
calc_type
Type of interferences considered:
0 - Intersections only.
1 - Both intersections and penetrations.
2 - Penetrations only.
self_interferenc
Set to 1 to consider self-intersections and penetrations within component, otherwise set to 0.
check_method
Used to specify a stricter definition of penetration - one requiring all nodes on element to be within proximity distance for the elements to be added to output mark.
0 - To avoid.
1 - To utilize stricter method. This stricter check is not generally recommended.
proximity_dist
Proximity distance - a float value greater than 0.0.
pair_angle
Only include elements forming interference pair with another element within this angle - a float with values ranging from 0.0 to 90.0.
threshold_depth
Results avoid elements penetrating by less than this value - float value greater than 0.0, and less than the proximity_dist.
Place on mark 2 the elements contained in component mark 1 that are within 2.0 proximity distance. Furthermore, avoid including any elements whose interference element partner’s normal differs by more than 45 degrees.
*calculateproximityelements comps 1 2 0 2.0 45.0 0.0
   # Handle error
Version History
9.0
