*setgraphictranslation
Graphically translates the specified entity.
*setgraphictranslation entity_type entity_id x y z
HyperMesh Tcl Modify Command
Currently only supported for FE inside of components.
entity_type
The type of entity to graphically translate. Only supported for components.
entity_id
The ID of the entity to graphically translate.
x
The x value of the graphic translation. A value of 0 indicates no translation.
y
The y value of the graphic translation. A value of 0 indicates no translation.
z
The z value of the graphic translation. A value of 0 indicates no translation.
Examples
To set the graphic translation of component 100 to 3, 0, 0:
*setgraphictranslation comps 100 3 0 0
To unset the graphic translation of component 100:
*setgraphictranslation comps 100 0 0 0
   # Handle error
Version History
11.0.130
