*evaltclscript
Run a Tcl/Tk based script file.
*evaltclscript filename flag
HyperMesh Tcl Modify Command
filename
Tcl/Tk file name to run.
flag
Flag to run command end functions.
Default = 0
This command allows you to run the Tcl/Tk based script supplied in filename.
The flag argument should be specified as 0.
