*findedges1
Finds element free or T-connected edges.
*findedges1 entity_type mark_id edge_type created_entity smooth break_angle
HyperMesh Tcl Modify Command
This command finds and displays element free or T-connected edges as either free lines or plot elements in a new component named ^edges.
entity_type
The entity types to find edges for. Valid values are comps and elems.
mark_id
The mark ID containing the entities. Valid values are 1 and 2.
edge_type
The type of edges to find:
  • 0 - Free edges.
  • 1 - T-connected edge
created_entity
The entity type to create on the found edges:
  • 0 - Plot elements
  • 1 - Free lines
smooth
The smoothing to use when created_entity is 1:
  • 0 - No smoothing.
  • 1 - Smooth the lines through the nodes.
break_angle
The angle specifying when to break the feature line created into multiple line segments when created_entity is 1. When the angle between adjoining elements along the feature is larger than the specified value, it splits the line into multiple segments.
To check the free edges on all of the elements contained in the component fender and to create plot elements:
*createmark comps 1 fender
*findedges1 comps 1 0 1 0 0
Version History
13.0
