*convertbeamsection
Updates the target solver ID for beamsections.
*convertbeamsection mark_id source_solver_id target_solver_id
HyperMesh Tcl Modify Command
mark_id
The ID of the mark containing the beamsections to update. Valid values are 1 and 2.
source_solver_id
The ID of the source solver for the specified beamsections. This can be queried using hm_getsolver.
target_solver_id
The ID of the target solver for the specified beamsections. This can be queried using hm_getsolver.
To convert beamsections 1-5 from solver ID 2 (Abaqus) to solver ID 1 (OptiStruct):
*createmark beamsects 1 1-5
*convertbeamsection 1 2 1
   # Handle error
Version History
10-SA1-130
