*pressureonelement_curve
Creates a pressure load on an element.
*pressureonelement_curve id face_index x_comp y_comp z_comp magnitude curve_id x_scale
HyperMesh Tcl Modify Command
id
The ID of an element on which to apply the pressure.
face_index
The face index of the solid element. Ignored, if the element is a shell element.
x_comp
The x-component of pressure.
y_comp
The y-component of pressure.
z_comp
The z-component of pressure.
magnitude
The magnitude of the pressure.
curve_id
The ID of a curve defining the magnitude of the load vs time.
x_scale
A scale factor applied to the x-axis (or time axis) of the curve.
To apply a pressure of magnitude 4.0 on the solid element ID 10 face index 2, using the curve with ID 9 to vary the magnitude over time:
*pressuresonelement_curve 10 2 0 0 0 4.0 9 1.0
   # Handle error
Version History
14.0
