*copymark
Copies entities from one collector to another.
*copymark entity_type mark_id name
HyperMesh Tcl Modify Command
entity_type
Entity type to copy. Any collected entity type (aside from master/slave elements) is valid.
mark_id
The ID of the mark containing the entities to copy. Valid values are 1 and 2.
name
The name of the collector to copy the entities to. The collector type is determined by the entity_type.
Examples
To copy all elements in comp1 to comp2:
*createmark elems 1 "by collector name" comp1
*copymark elems 1 comp2
   # Handle error
