*setcomptopologydisplay
Sets the various types of geometry display at the component level.
*setcomptopologydisplay compid disp_type
HyperMesh Tcl Modify Command
compid
The ID of the component for which you wish to set the topology display mode.
display_type
The type of topology display:
  • 0 - Wireframe only
  • 1 - Shaded with edges
  • 2 - Shaded without edges
  • 3 - Wireframe with internal surface lines
None.
