*surfacesplitwithsurface
Splits one surface with another.
*surfacesplitwithsurface surface1 surface2
HyperMesh Tcl Modify Command
surface1
The surface to be split
surface2
The surface used to split surface1.
To split surface 1 with surface 2:
*surfacesplitwithsurface(1,2)
None.
