*copymarkgroup
Copies master/slave elements from one group to another.
*copymarkgroup entity_type mark_id name
HyperMesh Tcl Modify Command
entity_type
Must be set to elems.
mark_id
The ID of the mark containing the master/slave elements to copy. Valid values are 1 and 2.
name
The name of the group to copy the entities to.
Examples
To copy all elements in group1 to group2:
*createmark elems 1 "by group name" group1
*copymarkgroup elems 1 group2
   # Handle error
Version History
10.0
