*CE_ConnectorCreateAndFERealizeForTrimMass
Create apply mass connectors at the specified location with certain rules, and realize them using a specified config type, mass value and distribution type.
*CE_ConnectorCreateAndFERealizeForTrimMass entitytype entitymark linkentitytype linkentitymark ce_rules ce_le_rule tolerance num_ents config mass distribution_type param1
HyperMesh Tcl Modify Command
entitytype
The entity type serving as the location of apply mass connector(s). Valid options are nodes and points.
entitymark
Mark of the location points or nodes.
linkentitytype
Link types:
  • Nodes
  • Elems
  • Comps
  • hm_tag
linkentitymark
Mark of the entities of links.
ce_rules
Rule to specify how a link entity is to be added to a connector:
  • 0 - None
  • 1 - User selected
  • 2 - Use name
ce_le_rule
Rule that specifies how an entity is to be remembered by the connector:
  • 0 - None
  • 1 - User ID
  • 2 - Use name
tolerance
Add entities as links only with in the given tolerance from the specified location.
num_ents
The number of links.
  • -1 - All entities within tolerance will be added as links.
config
Apply mass type:
  • 1100 - Point mass
  • 1101 - Rigid mass
  • 1102 - Rigidlink mass
  • 1103 - rbe3 mass
mass
Value of the applied mass.
distribution_type
Apply mass distribution type:
  • 0 - Divide mass by nodes.
  • 1 - Apply mass to all nodes.
  • 2 - Divide mass by area.
  • 3 - Unit area.
param1
For future use (must be 0).
Examples
This example creates 2 apply mass connectors at nodes 1 and 2, using nodes as links, adding nodes as links to the connectors using "proximity" tolerance = 10.0, and setting the remember rule to "none". It also realizes connectors using "point mass" (1100), "mass value" = 100.0, distributing the mass to the link nodes using the "divide mass by nodes" method (1).
*createmark(nodes, 1) 1, 2    *CE_ConnectorCreateAndFERealizeForTrimMass(NODES, 1, NODES, 0, 2, 0, 10.0, -1, 1100, 100.0, 1, 0)
