*createcenternode
Creates a node at the center of a circle defined by 3 input nodes.
*createcenternode node_id1 node_id2 node_id3
HyperMesh Tcl Modify Command
node_id1
The ID of the first node defining the circle.
node_id2
The ID of the second node defining the circle.
node_id3
The ID of the third node defining the circle.
Examples
To create a node at the center of the circle defined by nodes 100, 200 and 300:
*createcenternode 100 200 300
   # Handle error
