*systemconvertnodetoaxis
Converts systems from nodal reference to axis reference.
*systemconvertnodetoaxis mark_id
HyperMesh Tcl Modify Command
Supported only for OptiStruct and Nastran profiles.
mark_id
The ID of the mark of systems to conver. Valid values are 1 and 2.
Convert systems 2-5:
*createmark systems 1 2-5
*systemconvertnodetoaxis 1
   # Handle error
Version History
2019.1
