*morphupdateshapes
Updates or converts shapes.
*morphupdateshapes entity_type mark_id mode
HyperMesh Tcl Modify Command
This command can convert shapes to node, handle, or morph volume perturbations, convert shapes to load collectors and vice-versa, or correct shapes after perturbations are found on duplicate nodes or handles due to various operations.
entity_type
Must be set to shapes or loadcols.
mark_id
The ID of the mark containing the shapes or loadcols. Valid values are 1 and 2.
mode
  • 0 - Convert shape to handle perturbations
  • 1 - Convert shape to node perturbations
  • 2 - Add duplicate perturbations
  • 3 - Average duplicate perturbations
  • 4 - Convert shapes to forces
  • 5 - Convert forces to shapes
  • 6 - Convert shapes to temperatures
  • 7 - Convert temperatures to shapes
  • 8 - Convert shapes to pressures
  • 9 - Convert pressures to shapes
  • 10 - Converts all shapes and morphs on undo/redo list to node perturbations
  • 11 - Convert shapes to enforced displacements
  • 12 - Convert enforced displacements to shapes
  • 13 - Convert shapes to morph volume handle perturbations
  • 14 - Convert shapes to pressures. This creates pressures in the normal direction on all elements touching perturbed nodes.
  • 15 - Convert shapes to pressures. This creates pressures in the direction of the perturbation only on elements with all nodes perturbed.
  • 16 - Convert shapes to pressures. This creates pressures in the normal direction only on elements with all nodes perturbed.
  • 17 - Convert shapes to enforced displacements. This constrains the XYZ directions with zero perturbations.
To convert all shapes for the mesh into force type load collectors:
*createmark shapes 1 "all"
*morphupdateshapes shapes 1 4
if { [ catch {*morphupdateshapes...} ] } {
   # Handle error
