*elementqualitycollapseelems
Collapses/combines two adjacent trias into a quad.
*elementqualitycollapseelems elem_id1 elem_id2
HyperMesh Tcl Modify Command
This command collapses/combines two adjacent trias into a quad.
This command only functions between an *elementqualitysetup command and an *elementqualityshutdown command.
Current element quality criteria for optimization must be set before using this command. The command may be applied at any time without resetting the current quality criteria.
elem_id1
The first tria element ID.
elem_id2
The second tria element ID.
To collapse tria elements 10 and 11 using quality criteria from a file:
*readqualitycriteria c:/criteria/mycriteria.txt
*createmark elems 1 displayed
*elementqualitysetup 1
*elementqualitycollapseelems 10 11
*elementqualityshutdown 1
   # Handle error
Version History
13.0
